What heads for SLP headers??? Problems? Suggestions?
Old Jan 7, 2001 | 11:57 PM
Night Hawk's Avatar
I've read somewhere that the SLP headers won't fit alot of aftermarket heads. I have stock L98 cast heads on my 88 GTA. I'm strongly considering a head change but I'm very concerned with the SLP headers bolting up properly. What does everyone with SLP headers have for heads...any suggestions.
Old Jan 8, 2001 | 04:46 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
All aftermarket small block Chevy heads should have the holes drilled the same for exhaust manifolds or headers. The only problem may be with spark plug alignment. My SLP's clear the angled plugs easily on my ZZ4.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jan 8, 2001 | 06:27 PM
Dan87IROC-Z's Avatar
The best thing to do would be to call or email companies you are considering purchasing heads from. My suggestion for heads would be the AFR 190s or 195s depending on your application.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, LT4 HOT Cam, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
drathaar907
Aug 6, 2015 04:20 PM
