any parts stores sell an oil pressure gauge?
Old Dec 21, 2003 | 02:33 PM
llvll4l2c91350's Avatar
lookin for a gauge to hook up to the block to test the pressure. anyone bought one anywhere besides from the tool trucks?? i've seen compression and FP testers at parts stores but no oil pressure testers. i'd like to get one to test it out myself instead of bringing it to a shop.
TIA
Old Dec 21, 2003 | 03:17 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
you might check a local parts store.... they should usually keep at least one type of gauge in stock.
at the napa store where i work, i keep a couple different mechanical gauges in stock... there's also a couple stewart warner gauges i keep in stock. i can also order stewart warner, vdo siemens, and autometer....
Old Dec 21, 2003 | 03:30 PM
ede's Avatar
ede
it'd be harder to find a parts store that didn't have some sort of oil gauge, for that matter any gauge that reads in PSI would work. be best if it had 1/8 NPT.
Old Dec 21, 2003 | 03:41 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
even walmart has mechanical gauges in stock....
i'm pretty sure that the mechanical gauge kit should come with any needed adapters to connect the gauge.
also, when you get the oil gauge... be careful with the nylon line that connects the gauge to the fittings... it kinks very easily.
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
