Any hidden costs in a 700R4 swap 2 T-56?????
Old Jan 8, 2001 | 10:31 PM
MATEOZ28's Avatar
I've read some tech articles and am seriously thinking of doing the swap but I'm curious of ANY hidden costs of the swap. I put a 383 in my 1991 Z28 and there were quite a few enexpected costs I didnt budget for and can't afford to go through that again. Any help?
Old Jan 9, 2001 | 06:04 PM
82z's Avatar
82z
You need a new flywheel, clutch, pressure plate, clutch hydraulics, clutch pedal, and crossmember. You will also need a shifter but you may be able to get that with the tranny. Good Luck
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Jan 9, 2001 | 07:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's relatively straightforward.
A few small hidden gotchas involve the speedo; make sure you get a VSS, and the right speedo gears for your rear. Also, only a V8 trans will work, as the 6-cyl one uses a different clutch disk, and though you can change that, the 6-cyl unit's gear ratios are not right for a V8. You may need a chip from a 5-speed since you won't have a torque converter lockup clutch. You'll need an entire pedal assembly: it contains both the clutch and brake pedals and is quite different from the auto, but they interchange easily. Like 82 said, get as much as you can with the trans; go to the boneyard and strip a car if you can.
Street Lethal
Apr 30, 2019 12:14 PM
camaro11j
Sep 19, 2018 08:49 AM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
cRoe4
Aug 7, 2015 08:46 PM
