Problems with GM's fuel gauges
Old Dec 22, 2003 | 10:27 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Newspaper article
While this may not be thirdgen specific, it could affect our thirdgens and pose a potential safety hazard. It's something we all should be aware of.
Pete
Old Dec 22, 2003 | 11:05 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
GM has had a problem with the fuel gauge for YEARS.
I know when mine hits 1/2 tank...watc out cuz the needle drops like a ton of bricks.
Old Dec 22, 2003 | 01:17 PM
iroc22's Avatar
I guess no one pays attention to their trip meters anymore.
Old Dec 22, 2003 | 01:27 PM
Daemorok's Avatar
my trip is broken, and my fuel gauge is usually off by a good amount, its fun
Old Dec 22, 2003 | 06:42 PM
Pat Hall's Avatar
I've been through the fuel gauge fiasco as well. I changed out the sending unit in the tank with the theory that the sending unit is usually the culprit. After changing that, it still did the same thing. I decided to fix my broken trip meter so I could keep track of my mileage easier between fill ups. While I was at it, I had an extra fuel gauge from another cluster and swapped it in. Whaddya know, it works pefectly with the different fuel gauge in it! If I ever end up with the same problem again, I'll definitely try changing the gauge before the sending unit. The only thing that made me not feel so bad about the hassle of changing out the sending unit was that I was changing rear ends at the time, so it wasn't that much more of a hassle to drop the fuel tank at the time.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
