can my car wear this rear end gear ratio?
Old Dec 23, 2003 | 02:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
since I currently have a 3.08 rear end Posi unit, I heard this is a 2-series rear end, so i am assuming this part will fit? its a 3.73 gear and pinion set 2 series carrier. Any objections before I order?
http://store.summitracing.com/partde...=RMG%2D4900071
Old Dec 23, 2003 | 08:20 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: can my car wear this rear end gear ratio?
A 3.08 is a 3 series not 2.
Old Dec 23, 2003 | 08:29 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Re: can my car wear this rear end gear ratio?
Are you sure, I thought 3.23 and nemerically higher was 3 series, and 3.08 and numerically lower was 2 series.
Old Dec 23, 2003 | 08:38 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Well, it looks like the 7.5s are series 2 with 3.08s. I thought they were the same as a 8.5 as far as ratios went. Sorry.
Old Dec 23, 2003 | 09:19 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
As far as I know how the GM 10 bolt rear gears are, the 3.08 and 2.xx gears go with 2 series carriers. 3.23 and above are on 3 series carriers.
It appears that Richmond makes a 3.73 rear gear that fits on the 2 series carrier. I think that is what you want.
Old Dec 23, 2003 | 10:24 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I agree with doc...
Old Dec 24, 2003 | 02:33 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks, i actually found the same parts over at jegs, and they clarify, that the CAMARO 3.08's are 2 series and that my 3.73 2 series will fit
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
