Acceleration sucks
Old Jan 9, 2001 | 05:23 PM
86 Fbird's Avatar
Acceleration sucks
For about a week now when I am sitting at a light and it turns green and I press the gas to go my accelarates as if I have a honda or something.The RPM's go up to about 3200 and then it shifts and when it shifts it really shifts hard. It takes about 2 blocks to get up to 40 mph. Usually I get to 35 by the time Im at the other side of the intersection. Anybody have any hints please?
Old Jan 10, 2001 | 12:08 AM
crazygearhead's Avatar
Is you cat clogged? that makes things bad. Is it running rough? CHeck thecat first. first check if there is a good ammount of exhasut coming out of the pipes. if there isn't then check the cat. if it is REALLY hot then it's most likely clogged. replace it or hollow it out. Your car will go again.
If it breaks, it wasn't good enough anyway.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
wanext
Oct 6, 2015 12:18 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
3.8TransAM
Oct 1, 2015 07:47 PM
