Location of #1 cyl. on LG4
Old Jan 10, 2001 | 11:28 AM
TA76's Avatar
Stupid questions, I know... but I'm having trouble starting my 83 TA (305, 5spd) after installing a new cam and distributor. I set TDC using the front drivers-side cylinder, is that the #1? Thanks.
Old Jan 10, 2001 | 11:34 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Yep,front driver side cylinder is number one. Make sure is on top dead center on the compresion stroke or you'll be out 180 degrees.
Old Jan 10, 2001 | 11:40 AM
TA76's Avatar
Thanks, It could be out 180 but it seems to sputter a bit but never really gets going. I've moved the distributor a bit each way but no dice, it is getting fire though. I think I may pull the distributor and reset the engine to TDC and try again.
Thanks for the quick answer!
TA76
Lbibb
May 5, 2016 12:00 AM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
