Car runnin Rich
Old Dec 25, 2003 | 08:17 PM
92RedRallySprt's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
Car runnin Rich
I noticed earlier tonight my car was puttin out some black smoke.....and even when idling it was comin out the tailpipes....What could be causing this and how can I fix it???
The motor is a 5.0L 305 TBI
Old Dec 25, 2003 | 08:42 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Does it trip the service engien soon light? Has it had a tuneup recently?
Old Dec 25, 2003 | 09:05 PM
Car: '92 Camaro RS
Engine: 305 TBI
There hasn't been any codes. And I did a tune up at about 65k miles......the car now has almost 78k miles on it
Old Dec 26, 2003 | 01:55 PM
Vader's Avatar
Is the engine starting normally? Do you have any idea of the fuel pressure? Has the fuel and/or filter been changed recently? Does this only happen at startup or when the engine is fully warmed?
Old Dec 26, 2003 | 05:29 PM
Car: '92 Camaro RS
Engine: 305 TBI
The engine starts fine, I have no idea on the fuel pressure. I just put fuel in it about 5 days ago and to my knowledge the fuel filter has never been changed......it only happens when the car is a little cold.
Old Dec 27, 2003 | 11:00 PM
Vader's Avatar
I've experienced that on TBI engines when the fuel pressure is low. The ECM goes a bit rich to compensate for the lack of fuel flow, and the injectors don't atomize fuel as much as they dribble or stream it out. That creates accumulation of liquid fuel in the intake, and some cylinders get an excessively rich mixture as a result.
I'm not saying that's necessarily what's happening to you, but it's a possibility. If you could test fuel pressure, you might be able to find this kind of problem or eliminate it as a possibility.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
squiggy2
Aug 9, 2015 09:30 PM
