Cold Weather Woes
Old Jan 9, 2001 | 09:05 PM
stalemate's Avatar
Cold Weather Woes
My car is not starting. I didn't start it for about a week or so. Then when I went out to start it, it wouldn't. Jumped it and it started. But wont start the next day. A couple of days later it starts. Now it wont start and wont start when jumped. I first thought it was the battery, but then had second thoughts. Why would it start sometimes? Any help appreciated.
Andy
Old Jan 10, 2001 | 08:51 PM
Vader's Avatar
Stale,
Presuming that the alternator is charging, and the battery is holding a charge, you may have a load that is draining the battery or a failing connection in the battery/starter circuits.
Parasitic load (standby) should be less than 350mA. That is so little that a fresh battery should not discharge to a "dead" state for at least a month.
And since it won't start with a jump, I would suspect a failing cable connection.
Check the cables, grounds, and starter connections first, then test the battery under load.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Spyder_TheGamer
Oct 2, 2015 12:25 PM
3.8TransAM
Oct 1, 2015 07:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
