TDC ? Dot to dot right?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Ok the new cam is in but I am confused wheather or not I am at TDC for the #1 cylinder. Let me see if I get this.......
Dot to dot (crank gear at 12 o'clock, cam gear at 6 o'clock) is #6 piston at top of compression stroke. So what allignment to get the #1 cylinder at TDC. I want to adjust the valves soon but I want to start at TDC for #1 and do it with the car off. I have conflicting data between magaizines and my Chilton's/Haynes. They contradict each other. GM high tech performace says dots 180 apart is TDC but chiltons say that dot to dot is.... I am boggled here...
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Crank gear dot at 12 oclock and cam gear dot at 12. The cam dowel pin will be on the passenger side now. It's also one crank turn after the marks are how you described them.
Car: '90 RS
Engine: 377 LSX
Car: '94 Corvette
I think a lot of acticals and books tell you to do dot-to-dot, because it's easier to align. This is how I've done it for years, but yes dot-to-dot is tdc 6.
Ron
Ron
Car: '90 RS
Engine: 377 LSX
Ron
Ron
Car: 4
Engine: 6
Transmission: 5
Dot-to-dot is TDC for #1. However, it is the instance of #1 TDC during the full engine cycle that is not #1 firing. It is #6 firing, and #1 end of exhaust stroke and beginning of intake stroke.
Dot-to-dot is easiest to see, for building purposes. Asemble the engine that way to make sure you get the cam correctly lined up with the crank. It will be at #1 TDC, but #6 firing. Turn it exactly one crank revolution, and it will then be at #1 TDC, #1 firing.
you want both dots straight up. dot to dot is easier and it's how all the books tell you to do it, but they ought to put a disclaimer in that say's it's 180* out. i install the gears dot to dot then spin it a few times to make sure i'm not off a tooth on the gears then sdet both dots straight up.
Car: '90 RS
Engine: 377 LSX
RB83L69 and ede,
You guys are awesome. That is exactly what I needed to know and now I completely understand. Books and mags need to be carefull because they can really screw up their readers
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I thought it was the firing of #1 for the longest time and it caused a weekend of car that wouldnt start. I just put my finger over the #1 hole and feel for pressure then once its felt I put the timing on the 0* mark
