Checking heads
Old Dec 27, 2003 | 12:45 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Checking heads
How do you test the valves in sbc heads before you dissasemble them? What fliud do you use. Do you just poar CRC in the cumbustion chambers and let it sit overnight? what is the method? thanks
Old Dec 27, 2003 | 09:01 AM
ede's Avatar
ede
what are you checking them for?
Old Dec 27, 2003 | 01:39 PM
Car: 1987 GTA
leaks,..don't you have to put them on their side and pour some crc inthem, and see if it leaks down over night,.. shouldn't they hold the fluid? if it drains out,. the valves are bad, right?
Old Dec 27, 2003 | 03:57 PM
ede's Avatar
ede
ok yeha i guess you can do that. if i ahd the heads off i'd just grind the valves and seats and check everything for wear and cracks. replace seals and springs. i'd do a compression test if the heads were on the engine, that would give you a better idea of what you have.
evilstuie
Feb 28, 2016 03:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
anesthes
Aug 8, 2015 09:37 PM
