recall ?'s
Old Jan 10, 2001 | 03:10 PM
Mo's Avatar
Mo
recall ?'s
how do you know if your car has already been serviced after recalls were made? I am wondering cause i was reading on irocz.com that there were recalls on seat belt stuff a while back, but i dont know if the people who owned the car then took care of this
thanks
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Jan 10, 2001 | 05:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Dealers who repair car under recall are supposed to put a small decal listing the campaign number on the driver's door near the tire/weight information decal.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Old Jan 10, 2001 | 05:57 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Actually, now they go on the radiator support.
If your car was like '91 or newer, you could have a dealer type your VIN into the VIS Database, and it will tell you if it has been done or not. If your car is older, it would be hard to tell.
Not to mention, just because it is the same year as yours, there are VIN breakpoints that your car must fall within, so there is a good chance you are not eligable.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 10, 2001 | 06:14 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
they were able to check the vin on my 87 to tell me about the PS pump bracket tsb.. just needed the vin and proof of ownership.. as far as the seatbelts i was told it was never performed, but i couldnt do anything as they only run each campaign for i think 7 years? that he suggested finding the newer seatbelt latches in a boneyard...
Old Jan 11, 2001 | 12:00 AM
Ovrclck350's Avatar
Call you local dealer's service department and ask them about it. Give them your Vin number, an in 2 seconds they'll let you know if it's still outstanding or not. If it is, take it in, get free work. I received a new shifter cable and gas filler neck on my 92 Firebird today, compliments of GM. Hell, they coulda told me all I got was an ashtray or something and I'd have been happy.
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
GTAman
Mar 15, 2019 11:40 AM
topteam54
Oct 6, 2015 12:21 AM
Gordonr1973
Sep 29, 2015 11:59 AM
F-body-fan
Sep 17, 2015 12:16 PM
Eric2ndGen
Aug 31, 2015 11:30 AM
