Bore .30 or .40 over?
Old Dec 27, 2003 | 05:49 PM
Super Camaro's Avatar
Car: 88 Camaro
Engine: 5.8L 355ci V8
My engine has to be bored, so should I do the necesary .30 over or go to .40? How much horsepower would each one add? Can my stock pistons be used after its bored? If they can, let me know where I can get a single piston from an L05 with 9C1 package. (Caprice police package) one cracked, and they were damn good pistons, i'd hate to have to buy all new ones
Old Dec 27, 2003 | 06:52 PM
Car: 88 Camaro
Ok, I dont know why my post ended up in Aftermarket Product Reviews, cuz I did not list it in that thread
Old Dec 27, 2003 | 07:06 PM
ede's Avatar
ede
i'd only go over to the next size, not anything extra. you won't make any more power, or not make any more power that you'd notice going over more than you need.
Old Dec 27, 2003 | 10:23 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You can't do either, .30 or .40 over will cut your cylinder bore completely away. But .030 or .040 will work!!! If you can only go .010 or .020 if you can get pistons that size, save room for future rebuilds. You can't use stock pistons if you bore it, buy a matching set. You could find a good piston in a junkyard and just have the bores honed a little and reuse the stock pistons with new rings, but that is the poormans rebuild, it won't last very long, maybe 20-30,000 miles.
Old Dec 29, 2003 | 05:34 AM
ede's Avatar
ede
you can't replace a single piston. they're weight matched sets, unless you balance and match all 8 pistons.
Old Dec 30, 2003 | 10:09 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I agree with everything said so far.
Only bore the engine as much as possible. If it will clean up with a .030" overbore then only do that. This way you save meat for future rebuilds. Small block pistons also often come in .020" oversize, so if you can get away with this it would be even better.
Replace all the pistons as a set. They are weight matched as noted. I've pulled engines apart that had one piston bigger than all the rest, and couldn't help but laugh. This is really the wrong way to go about a rebuild. You have the engine apart, and the car out of comission. Do what it takes to get another 150,000 or more miles out of it before it needs to be rebuilt again, rather than just cobbeling it together to get it running again. You'll be much happier with the results if done right.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
hartsmike
Oct 2, 2015 07:11 AM
jlta85
Sep 22, 2015 12:18 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
