Cast or Forged Center Link
Old Dec 28, 2003 | 07:49 AM
GTA88's Avatar
Hi,
I went to the parts stors to check out some center links. I looked at a "TreadSaver" , supposedly the generic form of Moog, made in the U.S.A. on the box. which had an edge going down the length of it. Then I checked out a Perfect Circle, which did not have an edge ( it was just round).
The TreadSaver looked heavier than the Perfect Circle.
I remember someone talking about cast vs forged suspension parts.
Is the center link with the edge cast, maybe ? And would that make it any better?
Old Dec 28, 2003 | 07:59 AM
HeavyBreathinRS's Avatar
Car: 1990 RS
A forging is stronger than a casting exactly because the flow lines from the forging operation are designed specifically to handle the stresses.
It is possible/likely that the piece with the split line is actually a forging. The line is formed as the top and bottom dies close together.
Old Dec 28, 2003 | 08:34 AM
ede's Avatar
ede
i don't think you'll find any front end parts that are cast. a forging has a wide flat parting line and a casting would have a narrow nearly to a point sharp parting line. there is also investment castings to consider but i don't think you'll find them on a front end and powdered metal that might be used.
Old Dec 30, 2003 | 07:43 AM
GTA88's Avatar
Thanks for the info. I think I'll get the TreadSaver.
gta892000
Aug 11, 2019 11:16 AM
355tpipickup
Sep 13, 2015 11:35 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
