quick engine stand q
bought one today from advance auto. says 750 lb max weight. this should be fine to hold a SBC fully assembled right? just wanna be sure. have no idea how much one of these motors weighs. thanks.
Car: 4
Engine: 6
Transmission: 5
Yep, a SBC in normal full dress weighs about 600-650. Lighter the more aluminum you use, heavier the more stuff you bolt on while it's still on the stand (starter, flywheel, brackets, whatever) believe it or not
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just be sure its bolted on tight with grade 8 bolts.
using cheap bolts, they can bend... i havent seen them fail, but its no fun wiggling a bent bolt out of the block/engine stand... and if it did fall, it would SUCK.
and even grade 8 bolts will bend if they arnt atleast snug...
NinjaNife
Aug 23, 2015 11:49 AM
