Fitting A mechanical fuel pump to a L98
Old Dec 29, 2003 | 08:05 AM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
Does any one know if The L98 fitted in the Gta's have the Hole drilled for the mechanical fuel pump push rod.
I have to fit one of these pumps to go back to a carb setup either that i will need to fit a low pressure electric pump..
But i already have a stock mechanical fuel pump to hand....
Also how did anyone reroot the transmission cooler water pipes which seem to be bolted via a bracket right where the mechanical fuel pump is supposed to fit.
Cant fit the pump as the pipes are in the way and they seem to be steel..
Old Dec 29, 2003 | 08:51 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Depends on the year. THey stopped drilling them out in 88 or 89 I think. Take a look at the block. If there is a block off plate, then chances are, the hole is there. No plate, no hole.......
Old Dec 29, 2003 | 09:02 AM
Engine: L98 350
i have an 89 gta and yes it has a blanking plate...Cheers
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
