cold start problem
Old Dec 29, 2003 | 09:19 AM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
cold start problem
from what i have read this seems to be a common "problem" on my 87bird (305 tbi)
if the car sits for a day or so longer, it takes a while to start. maybe like 10 seconds of turning over, then trying again with some gas, and then it'll start, but will stall out if i dont give it some gas and rev it up a few times. then it will idle high (like 1100) for a couple minutes.
i have heard that this is common from a cold start, but im in hawaii. and it doesnt really get cold here. how can i fix this?
thanks
Old Jan 2, 2004 | 12:01 AM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
i have heard people having similar problems because of a leaky fuel injector, is that a likely problem? im going to replace the sparkplugs soon anyway, but i doubt they are the problem.. anyone know what else could be the problem?
Old Jan 2, 2004 | 02:43 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
I've got the same problem with my car, but it is a TPI. I've replaced all the follwing:
fuel pump
fuel pmp relay
coil
rotor and dist. cap
pick-up coil
VATS system, all intake gaskets to check for air leaks.
The only thing I haven't gotten to is the fuel pressure regulator and yes, you guess it, the leaky injectors. I'm thinking that is probably part of it. I would consider taking a good look at the injectors since you only have 2 of them.
Old Jan 3, 2004 | 02:43 AM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
if it is the fuel injectors leaking, i guess the car might not be starting because theres too much fuel in the chambers or none at all (and none in the line either). would a fuel pressure guage help diagnose the problem? can anyone with a tbi share their experiences with what guage they used and the installation?
i have been looking at jegs 0-30 guages
http://www.jegs.com/cgi-bin/ncommerc...97&prmenbr=361
should i get that?
thanks
Old Jan 3, 2004 | 03:13 AM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
oh, and can anyone recomend where i can get fuel injectors? ive seen them used on ebay for cheap ($40) for two, but as much as $150 each new from various sites.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
