RPM, MPH, Tire diameter, tranny gear ratio, Whats the formula?
Old Dec 29, 2003 | 07:10 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
hey do you know the formula where you plug in your rpm, tranny gear ratio, mph, and tire diameter to find your rear end ratio?
I know you can find it in the equations page, but I need the actual #s you plug in.
Old Dec 29, 2003 | 07:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The numbers:
For mph, look at your speedo (or better yet, time yourself on a measured stretch of road)
For RPM, look at your tach (which if it's a factory one is probably wrong, specifically too high)
For tire size, use a ruler
For gear ratio, use 4th gear if it's a T-5 or D not OD if it's a 700, and that's 1:1
Sorry, I can't tell you what your particular numbers will all be.
Old Dec 29, 2003 | 08:01 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
the equation isn't too difficult to figure out if you think about it.
first, you need your tire diameter, then multiply that by pi.
that gives you the distance your car travels in inchs. with one revolution of the wheel. then divide that by 12 to get the distance in feet. then divide by 5280 to get it in miles.
using the transmission gear of 1:1, and a rear end gear of say 3.23:1, your driveshaft turns 3.23 times for every rotation of the wheels.
so we multiply the RPM by 60 to get revolutions per hour, or RPH
divide the RPH by the gear ratio(trasmission gear*rear axle ratio)
to get the amount of revolutions of the wheel per hour
take that and multiply it by the circufrence of the wheel in miles.
so
RPM*60/rear end ratio*tire diameter*pi/12/5280 = mph
or simplified.
RPM/rear end gear*tire diameter*0.002975 = MPH
Old Dec 29, 2003 | 08:35 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
I know you told me I could quit, but I got it:
Final Gear Ratio=(RPM)(60)(Tire Diameter)(Pi)/(Tranny Ratio)(63360)(MPH)
Boo Yow!
-Corey
eightsixseven
Dec 16, 2024 01:50 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
