air conditioning
Old Dec 29, 2003 | 08:16 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
air conditioning
hey i have a 83 firebird v6 and want to get rid of the AC. do i need to plug any holes and can i keep the belt off of the thing the conditoners hoses run to or does that serve a dual purpose? or can i just totally remove that? thanks eric
Old Dec 29, 2003 | 09:17 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
the ac belt should just be for that...
your alt belt should control your water pump, and if u plan on using/hooking up your ac in the future, you should cover the openings of the lines so nothing can get into it.
also, be careful when disconnecting the lines as freon is a harmful substance.
Old Dec 30, 2003 | 01:07 AM
MdFormula350's Avatar
were u going to use heat? if so you can get a standard heater box here
http://members.***.net/iroczdave1/IR...rts%20Page.htm
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
