car idles but when driving dies
Car: 90 T/A GTA
Engine: 350 tpi
i start my car and let it idle it will be fine i put it in drive and try and drive a block and it sputters bad, so bad that it is undrivable. i checked fuel pressure and that is fine, changed o2 sensor and starter. i scanned it and nothing came up, alos there is no check engine light. what do u think could be wrong. it's a 350 tpi speed density. thanks
Car: 1985 Iroc-z
Engine: 355 sbc
Originally posted by 85IrocNOH
could it be a failing ignition module?
grime and stuff can also be a culprit to many issues, throttle plates can be prevented from opening/closing due to it (my tempo ran like crap, this is what it came to be) so again like vader said, clean the throttle bottle with some carb cleaner and a toothbrush
1992 Trans Am
Aug 8, 2015 08:16 PM
