TPI heads
Old Jan 1, 2004 | 12:54 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
TPI heads
Hi !
Does any now how much lift the stock -87 tpi heads can handle.
Thanks!
Old Jan 1, 2004 | 01:54 PM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
I think they can take .500 max.....
i have managed .510 on 305 L69 heads with push in studs and standard springs but the dealer i bought the cam from did not recomend this as i had push in studs and standard springs......
i did 8,000 miles + with no trouble but maybe i was lucky.....:lala:
Old Jan 1, 2004 | 04:02 PM
ede's Avatar
ede
around .475 is my limit for pull out studs or stock springs. if you're changing cams there isn't any reason not to change springs and trash the factory rotators and replace them with aftermarket retainers.
Old Jan 1, 2004 | 08:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
a number of people have and do run 510 but, like already stated that is pushing it. I agree that it is pretty low lift I am using a 480/487 lift cam with push in studs on 305 tpi heads no problem so far but, I have better springs.
Old Jan 1, 2004 | 11:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI heads
Originally posted by Firebird sweden
Hi !
Thanks!
Stock heads and stock springs, no more than .460" lift. If you change the springs you can go with more lift, but I dont know for sure how much.
Old Jan 2, 2004 | 10:55 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
The retainer to seal distance limits you to around .500" on the cast iron 083s. I am running .492 lift (hotcam w 1.5 rockers)with mine and didn't have to mill the guides down, but it was close. I would recommend going to a lighter retainer and get new springs for any cam swap. I am running comp 981s(Scoggin Dickey $55) and LT1 retainers(Ebay $13.50 shipped w/locks).
Good luck,
Charlie
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
