MSD O-Rings and Modified Engine Block
Old Jan 1, 2004 | 08:45 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Has anyone ever installed the O-rings on the bottom distributor lands WITHOUT modifing the engine block. The instructions say that the seals can only be used on the modifed block, but all the modifications are some simple chamfered edges. I cant see what the trouble would be besides maybe risk during installation that they tear off and cause improper installation.
Any thoughts on leaving them on? They are supposed to increase the oil pressure by preventing oil from escaping past the gallery lands.
Old Jan 2, 2004 | 03:39 AM
ronterry's Avatar
Car: '94 Corvette
It will tear them up or off if your block isn't tapered, and you'll end up dropping the pieces into the block. Did you install the MSD with the O-Rings installed? Cause I would of thought it would have been hard if not impossible to seat the distr. without the block tapered.
Ron
Old Jan 2, 2004 | 06:42 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Ron
Yeah what he said ...Its definately not a good idea to put them on.
Old Jan 2, 2004 | 08:17 AM
Car: YTG Camaro
Engine: 383
No they aren't in.
I am going to call the engine builder and ask him if he tapered the edges. I told him I had an MSD but I never realized this requirement to specifiy the work. Oops!
Old Jan 2, 2004 | 08:26 AM
Car: YTG Camaro
Engine: 383
No they aren't in.
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
