AIR Pump...what's it do...
Old Jan 11, 2001 | 05:24 PM
squirrels's Avatar
My AIR pump on my 86 IROC is squealing like a trapped rodent...I changed the belt and I think it's the pump itself...question is, if this goes up, or if I remove the belt, will this affect the performance of the engine, or just my emissions? I'm gonna have to replace it...but if I just take the belt off for now, will it have any adverse effects?
Mark
Old Jan 11, 2001 | 06:22 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
No problem removing the belt. It won't hurt anything.
Its only emmission related.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 12, 2001 | 04:26 PM
squirrels's Avatar
So if I disconnect it it won't affect cold startup or anything like that, other than extra emissions?
Mark
Old Jan 12, 2001 | 04:39 PM
84TransAm's Avatar
Correct.. But i have heard that it could plug the catalytic converter, not to sure about that though. If u wanted to insure yourself against that you could always gut the cat, but be sure to run a pipe through there so you won't lose much torque....
--Steve S-- 84 Trans Am 305 (cough)LG4(cough), 5 speed, Flowmaster 80 series, otherwise an emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
P.S. Daily Driver
Old Jan 12, 2001 | 08:00 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
my friends *cough*mustang*cough* has the same problem....i told him to get a shorter belt and by pass the smog pump...you get an extra 6 or so horsies and its only emissions related
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Jan 13, 2001 | 01:45 PM
Skip Howard
Guest
Posts: n/a
The squeeling is the shaft bearing on it's way out. If you leave the belt on it'll freeze up on you and you can kiss your belt good bye. Gives a pretty good smoke show in the process too! It's best just to get rid of the belt for now and/or replace the pump. Mine's off till emissions test time...
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
