Loose Rod Side Clearance
Old Jan 2, 2004 | 02:16 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I was miking my crank before assembling my bottom end, and I measured the rod sideplay at about .020". This is larger than max according to the book I've got. Does anyone have any comment on this?
Old Jan 2, 2004 | 02:29 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The book I have says .010" - .020"
I'm sure you'll be OK, but I'm sure someone else will chime in and let you know for sure.
Old Jan 2, 2004 | 06:01 AM
ede's Avatar
ede
i have a lot of manuals, but i'd go with .015 as max and around .008 as the least. of all the specs for an engine rod side clearance is the least important to me. i would check the thrust and see if it's over spec, that i'd worry about.
Old Jan 2, 2004 | 09:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think it's fine. Like ede said, it's about the least important "spec" there is.
Run it.
Old Jan 2, 2004 | 10:21 AM
Car: '85 IROC
Engine: LB9
Thank you
It's nice to get good news every so often.
Old Jan 2, 2004 | 01:42 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
My stroker had abt .020 rod side clearance and I haven't had any issues. Abt the worst thing you'll encounter is slightly more oil being splashed onto the cyl walls which might lead to slightly more oil consumption.
Ghettobird52
Apr 21, 2020 08:44 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
Aug 20, 2015 09:36 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
