Low base air filter assemblies?
Old Jan 2, 2004 | 06:46 PM
StealthElephant's Avatar
Car: 87' Iroc
MY new engine sits alot higher then the old TPI, from the top of the carb there is probably only 1" of room. Thats from the tip of the primaries....does anyone make a 1=2" high assembly? Becuse there is no way one of those 4" high cleaners will fit, I need the LOWEST air cleaner possible, edelbrock has a metal mesh one, but I was told the filter falls apart. Does KN make a REALLY low clearance assembly to mount on a holley carb?
Old Jan 2, 2004 | 09:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The air cleaner that allows the most under hood clearance and performs the best is the one origionaly
used on 60-70's big block corvettes.
You can buy it or just the base from
Noah performance
They also often auction this aircleaner assembly on EBAY.
The choke housing and bowl vent tubes need to be shortened or removed
to allow this aircleaner to function properly with a holley carb.
Other corvette/ GM muscle car restoration parts sources
carry this too.
You can use a K&N filter element if you like 14x3"
Fits fine with room to spare even with the performer RPM
manifold and a NOS plate.
Old Jan 3, 2004 | 07:46 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Here is what I run on my 86 Z28. I even have a victor jr intake. You can see the filter I linked you too in the top left corner of the pic.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Sep 7, 2015 01:37 PM
