Daily Driver
Old Jan 13, 2001 | 04:38 PM
Keith5's Avatar
Car: C1500
Daily Driver
I've been have a recurring problem with my 90 cavalier. Sometimes if I have run on the interstate for about 10 miles and I get off at an offramp, it will die at the end.
It's beening doing this for about the past year. It just like if you don't push in the clutch pedal on a manual when stopping, but my car is an automatic.
Any ideas?
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
1985 Camaro IROC-Z LB9
http://www.geocities.com/krt80/
Old Jan 13, 2001 | 04:42 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Could be the lock-up converter switch sticking.
It will be JUST like what you said, coming to a stop in a clutch car without pushing in the cluch (bucking, stalls,etc.)
Usually won't do it around town.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 13, 2001 | 04:50 PM
Keith5's Avatar
Car: C1500
Do you know for sure if it is a lockup converter, or are you just guessing? I don't know which it is. I thought about that being the problem too, but I wasn't sure if it had a lockup. Where would the switch be, in the tranny or outside?
Old Jan 13, 2001 | 05:22 PM
Vader's Avatar
...or the TCC relay sticking. Or possibly (but not likely) the TCC itself sticking in the engaged position.
The '90 Cav should have a TCC, fer-shoor!
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 13, 2001 | 06:31 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
What Vader said..
The solenoid is usually located inside the side cover of the trans. (look through the drivers side front wheel well.)
Some cars require the front cradle to be dropped/lowered to get the cover out.
Check it for codes, sometimes (depends on available data stream) it will throw a lockup code.
With a scanner on it you should be able to drive it and watch what the lock up solenoid is doing.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 13, 2001 | 08:39 PM
Keith5's Avatar
Car: C1500
Thanks Guys, this is very usefull information.
Old Jan 13, 2001 | 08:42 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
My moms 90 Cavalier did the exact same thing. It was a few years ago so I dont remember exactly what it was but it Was trans related.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
F.I. 57 Belair
Aug 23, 2021 01:09 AM
ramicio
Sep 28, 2015 01:18 PM
BWilcox
Sep 20, 2015 12:19 PM
david068513
Sep 18, 2015 10:36 AM
rsrookie
Sep 5, 2015 07:08 PM
