injector why swap?
Old Jan 3, 2004 | 10:05 AM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
injector why swap?
i have a 305 tpi a bit modified and i have 8 injecton of a mustang 89 they seems to fit intoo mi stock intake how do i know if i should put them?
Old Jan 3, 2004 | 10:30 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well if the injectors are from a stock Mustang V8, then they'll be 19 lb/hr. They should be orange if that's the case. Which wouldn't make a difference from your stock injectors. But I'm pretty sure they would work, in case you ever need them for a backup set if one of yours fails or starts leaking.
Old Jan 3, 2004 | 10:44 AM
FOX-GTA_89's Avatar
19lbs
im sure mine are less than 19 i guess 13psi by the hayne book
and yes they are orange!on the question when yo need to upgrade the injector with smalll modification of after 800whp?
understand ehat i mean?
Old Jan 3, 2004 | 11:02 AM
Nixon1's Avatar
Well the 2.8's/3.1's, the V6's, got either 14 or 16 lb/hr injectors. And I'm sure the V8's got larger injectors. So yours SHOULD be right around an 18 or 19 lb/hr or so.
My experience here is with a Ford...but 19 lb/hr's will support over 300 horsepower. But once you start getting over 300, bigger ones will give you extra power. I don't know what the injector sizes are on the Chevys, but you could probably benefit from some 24 lb/hrs.
Street Lethal
Apr 30, 2019 12:14 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
