Non thirdgen---Need help with pulling codes on '00 Ranger 3.0L
Old Jan 13, 2001 | 01:33 AM
My Slow Iroc-Z's Avatar
Please help my broke a s s Ford!!!!
Old Jan 13, 2001 | 07:21 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sorry, no can do. You need an OBD-II compliant scantool. No more paper clips. Just make sure the gas cap is tight.
If you don't care what the codes are and just want the light off, remove BOTH battery cables and hold them together for 30 seconds. This will discharge all of the capacitors in the ECM. MAKE SURE there is no other battery source hooked up!
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 14, 2001 | 02:05 AM
Thanks GMTech....I took it to the dealorship and they replaced the MAP sensor...they said when the ECM opened the EGR valve the it was looking for a drop in manifold vacuum but the MAP sensor didn't show that the EGR had opened so it set the code.
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, 3.8L Turbo V6 200* fan switch, MSD GM coil, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 oil, and more to come...
Best ET not corrected- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Jan 14, 2001 | 03:17 PM
Marc 85Z28's Avatar
Why would you try to diagnose a problem like this yourself? It is a 2000 model right? Then it is covered under Ford's warranty. Free repair!
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
