vortech heads/ manifold for tbi/ annoying problem
Old Jan 12, 2001 | 11:28 AM
jeff88convertible's Avatar
Did the engineers @ chevy come up with a intake manifold that will accompany these heads on my 305(minnie mouse)? Heres the problem, the manifold must be able to use the factory or holley t.b.i. unit. Looking for a direct fit in all aplications if possible. One other problem I am experiencing as of latley when the car slows down (automatic no shift-kit)it kicks down or bumps just before it brakes to stop. Local mechanic couldnt figure it out! any help please? thank you third. gen. heads!!!!!!!!!!
Old Jan 12, 2001 | 02:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The good vortec heads are only made for 350's, and I dont know of one that will fit our TBI intakes.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 12, 2001 | 06:13 PM
Pat Hall's Avatar
The bumping problem in your tranny could be related to the TV cable. Mine did that when the TV cable became disconnected at the throttle linkage. It also shifted into the next gear way too early upon taking off from a stop. Check and see if it's still hooked up, and if so, try readjusting it.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 13, 2001 | 05:07 PM
Tas's Avatar
Tas
there is a 305 Vortec rated at 230HP in the trucks. The engine is the L30, the 350 Vortec is the L31. the heads per pair are pricey at $754 but maybe you can find some off a truck. check the TBI board for more vortec head info. there are a couple good posts over there.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Jan 13, 2001 | 07:06 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
were'nt any of the vortec trucks tbi?
Old Jan 14, 2001 | 05:40 AM
Tas's Avatar
Tas
no the vortecs never came TBI. They were CPI or something. Not true 8 injectors. they had 8 popet hoses running fuel to the intake valve.
Old Jan 15, 2001 | 09:57 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
If you're using vortec heads you need a specific vortec intake, because bolt patterns on a vortec head won't accept regular SBC intake bolt patterns. Get an Edelbrock Performer RPM Vortec Intake or Performer RPM Air-gap Vortec intake. Then go to Holley and get a carb -> TBI adapter. Hope this helps
Street Lethal
Apr 30, 2019 12:14 PM
db057
Sep 4, 2015 07:57 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Out-Cast
Aug 22, 2015 07:49 PM
theurge
Aug 21, 2015 12:46 PM
