lt4 hot cam in old block?
Old Jan 5, 2004 | 09:02 PM
mavis_1's Avatar
Car: 89 iroc convertible
Engine: 305 tpi
does anyone know if a lt4 hot cam will fit in a pre 85 block?
Everything I have found talks about puting in in a newer block.
thanks for your help.
Old Jan 5, 2004 | 09:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you get this cam for free or as a gift. You can get a pre 86 (non hydrualic roller) cam with the same specs for less money than the hot cam costs.
Old Jan 5, 2004 | 09:28 PM
mavis_1's Avatar
Engine: 305 tpi
Im interested in lt4 hotcam because I want to go full roller. Thanks for the tip though.
Old Jan 5, 2004 | 09:37 PM
Damon's Avatar
Yes, BUT.....
You'll need to use a roller cam timing chain set. You'll also have to use the factory roller cam retaining plate between the cam gear and block with the ears machined off (basically it becomes a "spacer" at that point) and then use a thrust button setup on the nose of the cam to keep the cam from "walking" forward when running- similar to an aftermarket roller cam conversion.
Also, the factory roller lifters will be too tall for the earlier non-roller cam block so you will have to go aftermarket for the roller lifters and their retention method (can't just bolt in a factory spider/dogbones, etc.)
In short- a huge PITA.
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
