Stall speed of stock converter in TPI
Old Jan 7, 2004 | 07:39 AM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
Does any one know the stock stall on a torque converter of my th700r4 in my 89 GTA.
or highest idle cam i could use without changing converter....?:lala:
Old Jan 7, 2004 | 08:27 AM
ede's Avatar
ede
you can find your stall speed by holding the brake and massing the gas. the stall is the rpm the car either has to move or die.
Old Jan 7, 2004 | 08:59 AM
Engine: L98 350
I will find that very difficult as the engine is apart...
Does anyone know what they are rated at?:lala:
Old Jan 7, 2004 | 09:06 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
900-1100
Old Jan 7, 2004 | 10:23 AM
Engine: L98 350
Old Jan 7, 2004 | 04:48 PM
Damon's Avatar
Like all automatics the actual stall speed will vary slightly depending on the torque of the engine. However, most TPI automatics will actually stall around 1600-1800 loaded up fully against the converter, rear wheels not allowed to turn at all. Usually the torque of the engine overcomes the rear brakes and starts to spin the rear tires before you reach actual maximum stall speed.
Old Jan 7, 2004 | 09:38 PM
Engine: L98 350
cool...
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
gta power
Aug 13, 2015 06:15 AM
