Did I FRY my Trans Am's Computer?
Old Jan 14, 2001 | 07:23 PM
Tom Batts's Avatar
Old Jan 14, 2001 | 07:47 PM
Vader's Avatar
Tom,
Maybe, maybe not. What engine/trans/fuel system do you have?
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 14, 2001 | 07:52 PM
Tom Batts's Avatar
Old Jan 14, 2001 | 07:55 PM
Vader's Avatar
Tom,
Never mind, I just caught the signature. Since the TPIs mostly had automatics in '86, I can guess it's a TH700-R4.
Since it's a TPI, the ECM is more involved in engine control than the carbed L69.
Disconnect the battery for about ten minutes. While the battery is disconnected, turn on the headlight switch (I know they won't work, but the load will completely drain any residual power from the ECM components faster.) While the battery is disconnected, you might as well clean the cables. When that's done, check the fuel pump fuse near the battery. It supplies not only the fuel pump, but ECM as well.
Replace the fuse if it has failed. Reconnect the battery and allow it to charge from either the jumper cables or a charger. Jumping to start it shouldn't be a problem. Before attempting to start the engine, watch the SES lamp while you turn the ignition switch to the RUN position (not START). The SES should light, go off briefly, then light again and stay lit until the engine is running.
Report back as to whether the SES flashes or turns on at all.
Waiting for results...
Later,
Vader
[This message has been edited by Vader (edited January 14, 2001).]
Old Jan 14, 2001 | 08:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Definatly sounds like you popped a fuse. Just hope thats all it is.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 14, 2001 | 08:59 PM
Tom Batts's Avatar
Old Jan 14, 2001 | 11:28 PM
Vader's Avatar
Originally posted by Tom Batts:
Thanks, Vader!!!!!!!!!
... I'll give it a try tomorrow. I sure hope you are right. I'll post the results when I know something. This board ROCKS.
Don't thank me. The entire board is made up of people sharing their experiences and ideas. I've learned a lot just by watching. I'll share whatever I can if I have a clue about the topic. And if the muck gets really deep, GMTech is one of the guys/gals that can bail you out. He and many other certified techs are a real asset to the board, not to mention those hobbyists that aren't certified but have a lifetime of knowledge and experience.
Put it all together, and yes, this board ROCKS!
Later,
Vader
KaleCo Auto Parts
Old Jan 15, 2001 | 07:47 PM
Tom Batts's Avatar
eightsixseven
Dec 16, 2024 01:50 PM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
stalkier
Aug 21, 2015 01:54 AM
jharrison5
Aug 19, 2015 05:53 PM
