How much gain would you get from this??
Old Jan 15, 2001 | 09:08 PM
Monkie's Avatar
Would you be able to tell any difference if you got a fiberglass hood and an aluminum radiator?
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Soon to be a 3.8L turbo RS
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX
More to come
Old Jan 15, 2001 | 09:11 PM
My Slow Iroc-Z's Avatar
Performance wise....no unless your engine is overheating now and you NEED the extra cooling capacity. Fiberglass hood might make the car look cooler if you get a cowl or ram air one....
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, 3.8L Turbo V6 200* fan switch, MSD GM coil, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 oil, and more to come...
Best ET not corrected- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Jan 15, 2001 | 09:12 PM
ede's Avatar
ede
i doubt if you save any weight with a aluminum radiator, but you'll save close to 75 pounds over stock with a lift off hood. that's close to a .1 in the 1/4. for the street it wouldn't matter and lift off hoods are a pain except for racing.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 09:23 PM
CamaroMike's Avatar
ede, the stock hood is only like 36 pounds. A bolt on fiberglass one from Harwood is 1/2 the weight.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 15, 2001 | 09:32 PM
ede's Avatar
ede
hinges, hood latch, someone told me stock hood was 65. i think the lift off harwood is 14 pounds. plus you have the brackets.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 10:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think ede's numbers for the hood are about right. However, the aluminum radiator is also a good 12 pounds lighter than the brass one, so there's a little weight savings there.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
