Thinking about one of those air sealer things.....
I was thinking about getting one of these for the MeanYellowZ, I don't know exactly what they are called but they attach to the air cleaner and then press to the hood of the car. Theres an opening in the back (towards the cowl) to let only the cold air to come in. Where would I find one? How much? Do they work good? Thanx....
**FOR SALE***89 Camaro RS 2.8 V6 auto
Exterior: White Interior: Black
T-tops, power-windows, locks, hatch.
Also, the new owner of the MeanYellowZ
Yah, I do have one, does anybody know where to get one of these?
Prolly made by the same people who invented the "Vornado" Don't buy that crap, that's retarded. That'd be like me running a vacuum hose from the wheel well to a funnel on my throttle body to let the TPI only get "cold air" that's gonna restrict your flow. Here's an idea, cut a hole in your hood and fiberglass a scoop on that b i t c h, that'll get ya some cold air.
my .02
Kelly
If you've gotta fix it, fix it better than stock.
my .02
Kelly
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
For a carbed car? An air cleaner base with a big foam doughnut around it? My car had one with the old carb, but it doesn't clear the electric choke on the Edelbrock. No idea where to get one though.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
mdtoren
Aug 16, 2015 05:45 PM
