How Do I Disconnecting The Speedo/odometer In My 91 Rs
Old Jan 9, 2004 | 02:27 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I have taken a cluster out of an 86 z28, it was cable driven so i disconnected the speedo cable. I was told that my 91 rs has an electrical speedo and was wondering how to disconnect the speedo and odometer and keep everything else functioning properly?
Old Jan 9, 2004 | 03:23 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
why do you want to?
keep in mind that is odometer fraud.
Old Jan 9, 2004 | 05:00 PM
THETANK's Avatar
Car: 91 rs
The only reason I want to is because i want to make sure that i put less than 5,000 miles on a year so i will not have to go through emissions. I have no plans on selling this car. and no intentions of trying to pawn it off as a low milage car or anything, it already has 130k miles on it.
Old Jan 9, 2004 | 07:05 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
pull the plug off of the sending unit on the side of the tranny and tie it up somewhere so it doesnt get ripped off while dangling under the car
Old Jan 10, 2004 | 03:44 AM
jasonbennett's Avatar
it will set off your ses light and not allow it to go into overdrive. it's not good to unplug that one.
Old Jan 10, 2004 | 05:32 PM
THETANK's Avatar
Car: 91 rs
so what sensor should be unpluged,, is there one that hooks directly into the back of the speedo?
Old Jan 10, 2004 | 11:17 PM
THETANK's Avatar
Car: 91 rs
ttt
Old Jan 11, 2004 | 12:44 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
jack up your car, get it up on jack stands.
from under the driver side, at the tailshaft of the transmission (just to the front of the driveshaft) you should see a sensor plugged in to the SIDE of the transmission.
theres a picture here that should give you an idea.
http://www.5speedtransmissions.com/tr-3550_pics_0.html
unplug that connector, and use a cable tie to keep tie it up out of the way.
and your done.
im not sure about 90+ dashs, but the 89 and prior, all gauges other than the speedo, didn't have any wiring, they have a connector built into the dash, and there are metal contacts on the cluster, so there is nothing to unplug. and the speedo is hooked up with a mechanical cable.
so i would imagine the 90+ the whole cluster would just snap in.
Old Jan 11, 2004 | 10:38 PM
THETANK's Avatar
Car: 91 rs
ok thanks a lot!!
