my car is flippin out
Old Jan 9, 2004 | 06:01 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
ok i have a 92 3.1 firebird and its like goin crazy... the rpm when im goin like jumps around on the tach but the car doesnt, and it has stalled a few times recently, at a light the car just cuts off and i was like woah... and it wouldnt start up... i would come back later and start it up... whats wrong with it is it the computer, fuel pump... when i try to start it up after it dies it will just keep turning over with out ignition...so and ideas?
Old Jan 9, 2004 | 07:08 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
are u getting any codes?
when u try starting it back up, are u getting any spark/fuel?
If it turns over, i would suspect a faulty ignition module (they are known to heat-up and fail)
can you hear your fuel pump prime? maybe you should check your fuel pressure, your pump could be your problem as well
Old Jan 9, 2004 | 07:25 PM
7plagues's Avatar
ok heres what i've figured it has to be with the fuel not spark because its not priming and what about these codes how do i find these out?
Old Jan 9, 2004 | 07:29 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
https://www.thirdgen.org/newdesign/tech/
worship that page
how to retrieve codes is under the MISC section, you'll see. your SES light on? if not, your not going to get any codes or it may be a bad light
seems like you've already found your error though...
perhaps its time to drop your tank and switch your in-tank fuel pump
Old Jan 9, 2004 | 07:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Or check his fuel pump relay and the fuses.
The Trickster!!!!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
