Double hump heads
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Double hump heads came on the corvette fuellie engines and were good castings in their day. With the advances in head technolgy and the affordable price of aluminum heads I see no reason to buy these 30+ year old heads then spend the money to have them worked.
Car: 4
Engine: 6
Transmission: 5
They also came on sleds in 69 and 70, 350s in Impalas and station wagons. Those had the accessory bolt holes that our cars need. That's what I have on my 400.
The other post is right though; I have enough machine work in mine to take over $800 to replace. Back when I first started building these up, there were no AFRs or Fast Burns or Edelbrocks or any other over-the-counter products like that, especially not at that kind of price. The only real opion we had was to dig up a set of the best junk we had and try to turn it into something fast. Nowadays you can get better power by far with the aftermarket pieces, ready to bolt up out of the box with basically no risk, and have aluminum besides.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only reason you would want them is if you race in a class that requires stock parts such as Stock Eliminator. If not then heads such as Dart's are better right out of the box and cost less since all the machine work is already done.
Camel back heads are a deal if you can buy them for much less than $100. If any work has been done such as larger spring pockets, screw in studs, large valves then the price will go up but the heads are still old technology and better aftermarket heads are easily available.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
