350 w/LT4 cam
Old Jan 15, 2001 | 10:49 AM
jmon92conv's Avatar
350 w/LT4 cam
Ok, I am building a 350 for my conv. I have a 30over 350 with ported alum heads. I am buying a edelbrock intake and ported plenum. Will the LT4 cam be to much for it or can the setup handle it? I want a good street motor with the ability to run some autocross in the summer. Basiclly I want a good all around motor.
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC
when it warms up Edelbrock STB maybe springs
Old Jan 15, 2001 | 11:39 AM
jmon92conv's Avatar
I mean the Hot cam...sorry
Jeremy
Old Jan 15, 2001 | 01:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you're getting the ported intake, and have ported heads, that cam will work great. I'm putting one in my new engine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 15, 2001 | 07:17 PM
jmon92conv's Avatar
thanks Kevin, do you know about how it will act?
jeremy
92 Z conv
5-spd B&M shifter
Old Jan 15, 2001 | 07:35 PM
Kevin91Z's Avatar
No idea, I havent put the engine in my car yet. Tom Keliher, along with other people around here, are using that cam with an aftermarket intake and good heads, and making very nice power. I'm hoping for mid 12's and over 325 HP at the wheels.
Old Jan 15, 2001 | 07:42 PM
jmon92conv's Avatar
are you using the 1.5 or 1.6 What kind of lift can I expect with 1.5 or can I use them?
Jeremy
92 Z conv
5-spd B&M shifter
Old Jan 16, 2001 | 01:24 PM
Kevin91Z's Avatar
I'm using 1.52 roller rockers so the lift will be about .498". With 1.5's its .492" and with 1.6's is .525". You can use whatever rockers you want, as long as your springs will handle the lift.
Old Jan 16, 2001 | 02:21 PM
jmon92conv's Avatar
thanks Kevin, I am also wondering how you are going to pass emissions.
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's
Old Jan 16, 2001 | 06:20 PM
Kevin91Z's Avatar
Very carefully. And no, I'm not paying someone either.
Old Jan 16, 2001 | 10:08 PM
CamaroX84's Avatar
What is the rocker ratio of the stock rockers? Thanks.
Old Jan 16, 2001 | 10:50 PM
Dan87IROC-Z's Avatar
The stock rockers are 1.5:1. So the LT4 Hot Cam lift with stock rockers is .492"/.492".
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 17, 2001 | 08:59 AM
jmon92conv's Avatar
Dan, how does your car act on the street? Idle, and drivability? Thanks,
Jeremy
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
