Main Bolt question for shortblock??
Old Jan 11, 2004 | 10:10 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I bought a shortblock and my old motor witch only had like 7000miles on it blew up and I have ARP bolts throughout this thing.Well I was thinking should I use my arp main cap bolts on the new short block or just leave the bolts that they put on there on??My dad said leave it cause its done but Its not like its alot of work lol. I just wanted to know if they migth be streched or if it will actually make anything stronger? Also same question for head bolts, I have ARP off the blown motor and the Vortec head kit i ordered from SDPC comes with new stock ones so should I use new stock or slightly used ARP?? thanks guys
Old Jan 11, 2004 | 10:15 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went with studs. If you change from bolts to studs you will need an align hone to have it properly done.
Old Jan 12, 2004 | 04:38 AM
ede's Avatar
ede
if it's stock type engine there's nothing to be gained changing and you run small risk of messing something up. if there's a warrenty you may void it.
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
