Shaking begins at 70mph, and continues through 95+mph. What is it?
Old Jan 12, 2004 | 08:31 AM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
What are the possiblities for my car ('88 V6auto firebird) to shake at speeds over 70mph through 95+mph? It doesn't shake so much that i won't go that fast, but you can definitely see your chest and the dash vibrating while driving down the highway.
Old Jan 12, 2004 | 08:44 AM
conlinj's Avatar
check to see if the wheels are balanced, driveshaft balanced, alignment?
Old Jan 12, 2004 | 09:50 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
if its not tires and such, check out your tie rods, outter and/or inner, mine does the same thing, don't worry though it starts at 71 but after 100 or so it smoothes out again
Old Jan 12, 2004 | 12:15 PM
MurCurY's Avatar
Car: 86 Camaro Berlinetta
^ I have the same thing w/ my 86 Berlinetta....how hard is doing the tie rod ends?
Old Jan 12, 2004 | 09:47 PM
stevedave454's Avatar
Car: 91 S10
i would look into the driveshaft 93-97 camaros had a big problem with that
Old Jan 12, 2004 | 11:27 PM
a73camaro's Avatar
1. Jack up rear of car
2. Put on stands and chock wheels
3. Start car, put into D or OD any run up to 70-80 MPH. See if vibration is there. Turn off engine, apply brakes and try to avoid putting shifter into park.
4. If no shaking, then it is the road causing it. If it is there (the most likely case) unbolt your wheels, tighten the lugs nuts down to keep the drums in place and repeat #3.
5. Remove drums and repeat #3 EXPECT DO NOT TOUCH THE BRAKE PEDAL.
6. If vibration is still there, remove driveshaft and get it rebalanced.
Old Jan 18, 2004 | 10:40 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
The stock drive shaft on your car will still start to shake rattle and roll no matter how well balanced. You should find another one from a 4th gen donor or buy a new aluminum one. Buy a carbon fiber driveshaft and 0% vibration all the way up to 200mph
an aftermarket Aluminum driveshaft is good to about 150 mph without shaking your teeth out of your head like the stock one will do after 95 MPH.
ZZ3Astro
Aug 13, 2019 12:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
92-Formula
Dec 12, 2015 10:34 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
