Removing AIR/SMOG
Old Jan 13, 2004 | 12:49 AM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Removing AIR/SMOG
If i remove the AIR/SMOG crap on my car will it effect the emissions or the computer? Im trying to do something thats really really inexpensive that will pick up a little power. Any info reguarding this would be appreciated.
--I already have a custom computer chip that was done by a performance shop if that matters any.
Old Jan 13, 2004 | 02:02 AM
MdFormula350's Avatar
it will save you some weight, and give you more space. i dont see it adding 10 plus hp or anything.
i actually dont have any cats, non smog pump or any air stuff and headers and i almost passed emissions i was very close. i think if i just add cats again i should pass the test.
its well worth it just for the added space.
Old Jan 13, 2004 | 02:29 AM
RJR99SS's Avatar
You wont even notice any power gain if you do. I've removed a few on my cars, and the only reason i did so was to just free up some space in the engine compartment. At max i'd guess it would only free up like 1/2 to 1 hp at wot.
If you remove your smog pump, you might as well remove the cat too. The two work together, it dosnt make much sense to remove one and keep the other. Removing the cat will probably give you a noticable power gain.
Of course this absolutly will have a negative impact on your emmissions.
Old Jan 13, 2004 | 05:02 PM
Right now i have a high flow cat so removing it would be pointless? I passed emissions with flying colors with a cloged cat. and a very untuned car with bad muffler. Since being tuned i dont think it would have a problem even if i removed all this but im not sure.
Also, what is involved in removing all of this?
Old Jan 13, 2004 | 07:10 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
yeah, somebody doing a removal should do a step-by-step tutorial on air/smug equipment removal for the tech page...i could use some room under the hood
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
