Flat tappet in a roller block
Old Jan 13, 2004 | 12:16 PM
camarodude91's Avatar
My buddy just bought a 350 roller block and a set of heads at a swap meet. We want to build the engine but are on a tight budget. We wanted to now if a flat tappet cam and lifters will work in the engine because they are cheaper. We know that roller cams are better but we just don't have the money for a cam and lifter.
Old Jan 13, 2004 | 12:22 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It will. You will need flat tappet pushrods as well.
Old Jan 13, 2004 | 12:32 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Pretty good info in this thread.
https://www.thirdgen.org/techbb2/sho...hreadid=217852
Old Jan 13, 2004 | 12:50 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I know your on a budget but it's always sad to see a roller block used with a flat cam. However it will run for now untill you save some cash then put a roller like the hot cam in or an LT1 cam.
Old Jan 13, 2004 | 01:09 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Also note you'll need timing chain designed for non-roller motors.
Old Jan 13, 2004 | 01:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
timing chain, pushrods, lifter and cam....
if he has good stock rollers, he can save money by reusing the stock lifters and pushrods, and spending $50 on a used LT1 cam....
69GTOby
Apr 18, 2016 02:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
RyanJB
Sep 14, 2015 03:39 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
