Alum. Heads and Plugs
Old Jan 13, 2004 | 04:44 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey this is my first set of Alum. heads. Do I need any anti seize on the plug threads?
THanks
Brian Felts
Old Jan 13, 2004 | 05:59 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
No antiseize, just a little oil.
Old Jan 13, 2004 | 11:55 PM
ronterry's Avatar
Car: '94 Corvette
I use anti seize on my plugs...
We might a devided camp here???
Ron
Old Jan 14, 2004 | 01:33 AM
rezinn's Avatar
Yes, use anti seize. Make sure you get plugs for those heads, not the iron ones.
Old Jan 14, 2004 | 05:57 AM
ede's Avatar
ede
antiseize not oil
Old Jan 14, 2004 | 07:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, anti-seize, just a little so that it doesn't get onto the porcelain area of the plug. And don't R&R the plugs while the engine is hot, only cold.
RBob.
Old Jan 14, 2004 | 08:03 AM
ede's Avatar
ede
might want to try an in/lb torque wrench too just to make sure you don't over tighten
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
86IROC112
Aug 21, 2015 07:20 PM
MENINBLK
Aug 5, 2015 11:58 PM
