Camshafts
Car: '86 Z28 Chassi, '91 V8 S10
Engine: 350 bored .030 new cam, #416 heads with 1.94" intakes
Transmission: S10-NV3500 5spd
Camshafts
i want to install a better cam in my camaro before spring. i want to know what cam i should get. its goin into a sbc 350, and i would like to know if anyone know what the specs are for that cam. i was told the motor came out of an old k-5 blazer.
its gonna be basicly my car to drive around on the weekends and i plan on taking it to the drag strip every friday, but mainly i want something good on the street and good on the strip.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
ok here we go:
its a '76 chevy 350 bored .030 over which makes it a 355. its got a 600 cfm holley, with the holley contender intake manifold. stock heads, long tube headders, TRUE dual exhaust, i have a freshly rebuilt 700r4 tranny with a B&M trans pak, and before it hits the road this spring im goin to install a new ring and pinion set (3.73:1). the car is a weekend cruser and i will be taking it to the strip quite a bit this summer. im just lookin for what cams people recomend and what specs people recomend (lift, duration, etc..). any input would be greatly apreciated
Car: 4
Engine: 6
Transmission: 5
If it still has the stock 76 truck heads, they'll be the ultimate smogger crap, probably either 882 or 624 castings. Therefore, they have poor flow and very low compression.
I'd agree, don't go any bigger than the XE262. In fact the XE256 might be better for such a motor as that.
Car: 1985 Iroc-z
Engine: 355 sbc
with your set-up, i'd worry more so about your heads than your cam
save up n get a nice set of heads (i see decent ones on ebay go for under 500 all the time, ported n polished also) then throw in a cam and you wont be sorry
i just checked and i do have the 882 heads on that engine. i also have the origional 305 in my garage. and i recently did a valve job on them for an engines class i took in school. can i use those, ive heard of people doing that before. and if so, whats the best streetable cam for that.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The 882's should be walked out to the curb for the morning trash.
Your 305 heads are a good choice for a budget upgrade. The chambers are smaller which will raise the compression ratio on your 350.
The 305 heads have smaller 1.84"intake valves.
You should take them back to school and install new
1.94" valves and home port them.
Then they will work nicely for ya.
We've found that a Crane Powermax 278H-2
works well with this combination. (With the 3.73's and ported 305 heads/350motor.)
You can look up the cam specs here.
Powermax H278-2
Powermax H278-2
i was lookin up the cam in jegs and in fine print it says for 278 degrees a 2500 stall cam is required, would the 272-2 still have a good amout of power because it keeps the rpm range at 1500-5800.
well with a stock converter ( as long as its not too low of a stall speed. (2000rpm is ok) A high(er) stall will allow the car to launch better of course ( if you have the traction) It will improve acceleration of either cam.
But....
As long as you have the rear gearing and the compression ratio up near 10:1 the 278 will work well for ya. The 272 degree cam makes good power too. yes it will have a little more low end torque.
use a Performer RPM intake manifold.
the 278 is the best overall. It has a good broad overall powerband and drives nice on the street.
If you're going to go to a higher stall then get a 3000+ stall converter (9.5- 10") a 2500stall will not give you enough additional launch torque to justify the $$$ spent
Getting the heads right has more effect to the success
of this build than the cam does.
The 882's suck, that your biggest bottleneck.
But you already own a good solution, your 305 heads.
Upgrade your 305 heads as discribed, use a thin head gasket if nessessary to get the cr up to spec , and use the 278 cam and 3.73's. you'll like it.
Does the 350 have dished pistons or flat tops?
What converter do you have now?
A small 110-150hp nitrous kit will give you much more bang for the $$$'s than a new converter will.
The Crane H-278-2 is very NOS friendly too.
just right for a daily driver (commuter) that will be bracket raced on the weekends.
someone told me that i need to buy new pushrods too, if so why and what kind???
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
