327 build up
Old Jan 13, 2004 | 06:44 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
327 build up
Hey guys
I have been looking and cannot find any major buildups for 327's
My dad's friend is giving me a 327-365 thats in his impala( he's getting a 409)
I want to spruce it up a bit, but have no clue how too
You guys never cease to amaze me so..thought I would give it a try
Thanks for all your help again
AJ
Old Jan 13, 2004 | 06:48 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
They build-up like any other small block. We need a little more info on what you planning to do with it, and what setup your car has.
Old Jan 13, 2004 | 06:52 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
oops
Old Jan 13, 2004 | 08:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your accessories won't bolt to it, if it has the original heads.
Assuming you want to put it into your 87:
You could use your 305 heads on the short block, if it has flat-tops. Then your accessories would work. If you do that, get 1.94" intake valves put in them, and port them. Use a cam somewhere around 210-215° of intake duration, and as near .500" of lift as you can. Something like the Comp XE262. Obviously you need headers, exhaust, etc. You'll need a LH dipstick oil pan, and a 83-85 305 F-car flywheel. With those parts it will bolt right in and run OK, alot better than your 305 even if not quite as well as a 350 would.
Old Jan 13, 2004 | 09:15 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
OK, I thought so, I was just wondering
I am taking out my 305 and starting from scratch
I am going to sell my 305 as a mater of fact, it only has 33,000 on it.
I am planning on porting the old iron heads, headers, exhaust, victor jr intake, and CSI 2 inch carb spacer. I was wondering more on cam, and carb more then anything.
Also does anyone know what compression it has, I heard 11.0:1 and that worries me
Thanks alot for your help guys
Old Jan 13, 2004 | 09:44 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
When you take your heads off, then you can calc the CR based on what the piston vol, head vol, and deck clearance is.
I'm working on a 327 too. It's almost ready, I'm sure it will be a good motor. But in hindsight, I wish I'd bought forged pistons instead of the hypereutectic flattops I'm using, cause hypereutectics put limitations on future power adder usage.
Flattops are a good choice, a 64cc head can give you 9.75:1 CR (zero decked) and if you want to go higher than that, you can mill the heads.
Old Jan 13, 2004 | 10:59 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Cool
Thanks for the advice on the pistons, I will probably do it ( if money is there)
Good luck with yours...
Old Jan 13, 2004 | 11:06 PM
Car: '85 IROC
Engine: LB9
Thanks, I know I'll like it for awhile. And hey, the stock drivetrain will probably take all it can dish out.
Old Jan 14, 2004 | 04:39 AM
ede's Avatar
ede
l79? it should be i believe. you could sell it to someone that really needs one and have more than enough money to buy just about any crate 350 you'd want.
Old Jan 14, 2004 | 03:02 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Are they worth that much?
I mean if they are I will tell my friend to sell the damn thing
I was looking and they only made that engine for a few years.
Any ideas what something like that would be worth?
Old Jan 14, 2004 | 03:43 PM
ede's Avatar
ede
if it's a L79 from a vett or chevyII yes it's worth a lot to someone that need it fro a numbers matching restoration
Old Jan 14, 2004 | 04:16 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Ok thanks guys scratch that
I am going to tell him to sell it
Its from a 66 vette, I know that
I can't have him give me something so valuable
I guess he should sell it and complete his car
Thanks alot guys
AJ
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
