Need opinions
Old Jan 19, 2001 | 01:52 PM
84TransAm's Avatar
Need opinions
I was talkin engines with someone at work yesterday and he tells me a great way to make power out of a small block. Said to try and keep the piston at TDC for as long as possible, and that is where all the power from small-blocks are made. What do you think? (i can't remember if he said piston or somethin else)
--Steve S--
1984 Trans Am 305 LG4, 5 speed Auto
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
Old Jan 19, 2001 | 02:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The same goes for any heat engine. That's just simple thermodynamics.
The way you accomplish that is by using the longest rods you conveniently can. In practice though, the actual difference in power is only barely measurable, if at all, beacuse the amount of change is such a small percentage. It's a way for people with otherwise very closely matched or controlled engine specs to pick up just another tiny advantage on the other guy.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
