Vortec Heads Milled for a 305
Old Jan 18, 2001 | 08:14 PM
gruveb's Avatar
Car: 1989 IROC-1
2 questions.
First, if I puchase some vortec heads and want to apply them to my 305 HO, how much should I have milled off?
Secondly, if I later upgraded my 305 to a 350, how would that affect my compression ratio?
Thanks.
Old Jan 18, 2001 | 08:32 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
It'll bump your compression pretty far up on a 350. You'll need to use thick gaskets and pistons with a slight dish (you might get away with 4 valve reliefs if your gaskets are thick enough) to keep it reasonable. I'm not too sure about how much you'll need to shave, but you need to shoot for 58cc chambers.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jan 18, 2001 | 08:38 PM
gruveb's Avatar
Car: 1989 IROC-1
What size of chambers do the vortec heads have, and how would I find out?????
Thanks again.
Old Jan 18, 2001 | 09:29 PM
Mark305TBI's Avatar
The Vortecs have 64cc chambers. I had a Car Craft issue where they did a 305 build up with the L31 Vortec heads...I don't remember where that magazine is, or how much they shaved 'em. Go search the archives, you might be able to find something there.
-Mark W.
Old Jan 18, 2001 | 09:46 PM
Mark305TBI's Avatar
I found the Car Craft issue on-line. They milled 'em .045 and said they got just about 10:1 with .015" thick gaskets. That means they were right around 58cc chambers, maybe just a little less. Here's the article...
Page 1
Page 2
Page 3
Page 4
Page 5
Parts list
-Mark W.
Old Jan 19, 2001 | 11:41 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
If you mill some off of the head, are you not running a greater risk of the valves hitting the cylinder?? I am thinking of doing the same thing.
Old Jan 20, 2001 | 08:18 AM
ede's Avatar
ede
most engines i've built, with stock head deck thickness or even milled up to .03 using a zero deck block and flat top pistons will have around .25 valve to piston clearance. i always dummy up my engines with out gasket so you could add .04 to that. i wouldn't use a shim gasket ,you need a very good finish to make one seal. i'd go with a composition type gasket. i use fel-pros and spray them with a coat of k&w copper sealer and never had a leak.
ICON Motorsports
1st & 3rd
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
