just a stupid intake question. I WANT MORE NOISE!!
Old Jan 19, 2001 | 06:52 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Is there any way on a TPI 350 in an 89 GTA to get more of that classic wide open intake noise like that of a quadrajet? To me that is the finest sound in the world. I want it to sound like its going to suck the hood through the intake. I actually cut holes in my airbox and that helped a little. Any more ideas???
1989 GTA, L98/auto, t-tops, Black w/ grey int.
Ran a 14.85 @ 93.4 mph BONE STOCK
Old Jan 20, 2001 | 12:50 AM
84L69TA's Avatar
Car: 4 Mopars total
guys, this is a serious question. somebody out there has to know.....please
Old Jan 20, 2001 | 10:41 AM
Vader's Avatar
89,
With a MAF sensor, the necessary ductwork kills a lot of that resonance. As a matter of fact, the outlet side screen on a stock Bosch MAF is there partly to block some of the sonic shock waves that are created by the WOT "howl". These shocks can stress the hot wire in the MAF to the point of failure over time. If you had a speed/density arrangement, you could install an open element air filter right at the throttle body and make lots of howl, but you would be sucking heated underhood air, which would cost you some power.
You might want to consider a more open exhaust to increase the noise (and power) levels.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 20, 2001 | 11:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Mine made a pretty good "howl" when I opened up the lid on my home-made cold air box and before I put on a louder exhaust.
It still makes a bit of howl @ WOT, but the exhaust drowns it out pretty good. I suspect an open element on a Miniram would make more due to its shorter intake runners.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
GouldyGTR
Sep 7, 2015 09:05 PM
TheExaminer
Sep 6, 2015 11:40 PM
Ian Irvine
Sep 4, 2015 08:08 AM
