What diameter pushrods are in an LO3?
Old Jan 17, 2004 | 01:58 AM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
I am trying to put together some 416 heads and am having a hard time trying to find everything I need for them. I need guides, seals, valves, retainers, etc. I don't know what sizes to get. Can someone help me out. My motor isn't apart yet, so I can't look in there and see what I have. I would appreciate any help you guys could give me. Thanks.
Old Jan 17, 2004 | 05:25 AM
Vader's Avatar
It's easy to back off a rocker adjusting nut while counting the number of turns, tip the rocker out of the way, and remove a push rod. If they are stock push rods, they should be 5/16" (0.312").
Old Jan 17, 2004 | 08:02 AM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
THe rockers that I bought are for use with 3/8" studs....does that also mean that I need a 3/8" pushrod? Also, what is the diameter of the stock valves on 416's (I have to find new seals and guides)? Thanks.
Old Jan 17, 2004 | 08:29 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The stud diameter is completly independant from the valve stem and pushrod diameter. Any pushrods will work with the 3/8 rockers. Any dealer should be able to give you the guides and seals for the 416 heads. Just tell them what you have.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
