Big problem! No huge problem!
Old Jan 20, 2001 | 04:43 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok I'm in the middle of a cam swap. Today I pulled the Harmonic balancer off. So I take the old cam out put the new one in, also I'm installing a true roller timing chain. So I pull off the old crank sprocket and go to install the new one when I find the bolt hole in the crank is damaged!! I mean the bolt wouldnt even start. Does anyone have any addvice about taping the hole out? Or is there anyother way? I hate to beg but I got this far with inciden, help me please.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 170* Stat.
Best 15.414 @ 87.47.
Old Jan 20, 2001 | 06:09 PM
ede's Avatar
ede
i'm guessing you've never tapped a hole? you shouldn't have to really cut new threads, just clean up the ones you have. i'll guess you didn't use anything to protect the threads when you had a puller on the damper. buy a thread chasing tap instead of thread cutting. use something like wd-40 or tap oil. make sure you start out square and don't get the hole or threads crocked. good luck
ICON Motorsports
1st & 3rd
Old Jan 20, 2001 | 08:12 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Had the same thing happen to me. Had to start a tap and then was able to thread in the bolt. Freaked me out for a second too, but all is well
Old Jan 20, 2001 | 08:19 PM
Bort62's Avatar
Try actually stripping the snout Out, thats Fun
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
1992CamaroGirl
Dec 25, 2017 08:45 PM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
FreeSpirit
Aug 29, 2015 05:47 PM
JHX
Aug 29, 2015 02:30 PM
